Testing the movement resolution with the current linear threads obtained from the CD-Rom drives. Have decided to order 254 tpi adjustment screws which should offer much better resolution since currently the linear threads are around 2 to 4 tpi. These will allow for sub micron positioning possibly even reaching the nano scale without the use of the piezo tranlation stage which should then take over.
Hi Edward,
Did this progress ?
