21Step 21
Place the XLR jack in its hole and bolt it in place.
22Step 22
Carefully snap the LED into its holder.
23Step 23
Bend the wires for the audio jack so it will match its hole at the same time the USB port does. Carefully place them in their holes. If the audio jack is panel mount, screw on the mounting ring.
24Step 24
Put the bottom on the enclosure and screw it together.
25Step 25
Spray paint two coats of black enamel on the enclosure, and then one or more coats of clear enamel on the enclosure. Clear coat the bottom of the enclosure one extra time for extra protection.
26Step 26
Hot glue the standoffs to the bottom of the enclosure in the correct positions to match up with the protoboard.
27Step 27
Screw the protoboard into the standoffs.
28Step 28
Connect the USB cable again and ensure it still works.
The adapter is complete!
29Step 29
Now, go to the source folder and navigate to src/ti. Send the file DMXDEMO.8Xp to your TI-84 using your preferred linking program. If you don't know how to do this, read http://tiwizard.com/transferring-programs-to-your-....
Note that there is also a file called DMXDEMO0.8Xp. This is the source code and is not what you want right now.
30Step 30
Connect the link cable to your calculator and the adapter. Also connect the USB linking cable to your calculator and the adapter. Make sure the A end is connected to the calculator and the B end is connected to the Arduino. The Arduino will not accept the A end.
