Such a simple fix! It occured to me that I had left the Shift Register Clear pin floating. Tying it high (active low) immediately stabilised the output and reduced flicker to imperceivable levels!
A project log for Alpha Centauri
Big Alphanumeric Display Board – A pile of ultra-bright palm-sized 16-segment alphanumeric displays with network-based control
