I started writing a monitor programme for my Z80 computer last night, and got slightly frustrated by how difficult it was to test that my routines were working properly. So I wrote a Test Driven Development tool.
It's very much a work in progress, but the progress so far can be seen here: https://github.com/jamesots/zat
It's written in TypeScript to work inside Jasmine. Here is a brief example:
it('should work', function() {
zat.compile(`
start:
ld a,0
halt
org 20
newstart:
ld a,$12
nop
nop
breakhere:
ld a,$ff
halt
zat.run('newstart', {breakAt:'breakhere'});
expect(zat.registers.a).toBe(0x12);
It can also ompile external files and track and respond to IO and memory requests from JavaScript.
It's useable now, but it needs more work — in particular, I want to track IO automatically so that it is easier to write expectations about IO, and it needs to be packaged properly to use from NPM. I imagine the API will change a fair bit over the next few days (or whenever I get to look at this again.)
