After my DirtyPCBs order arrived, I was happy to find out that my design had no serious flaws (note to self: prototype hardware NEVER has enough test points) and tested it with an hobbyking 270 50-60 motor.
A project log for Redsuns Overdrive ESC
Open source car ESC running simonk based on the BlueESC from bluerobotics.
Agreed on the lack of test points. I've had that problem with my designs. Now I'm trying to run through my first power up and testing in my head before I order anything. Still not enough test points. :)
