Went and tested the harness and a number of issues and faults
- Had wrong connectors on end of harness to mate with connector
- Blew fuse for washer pump. Replaced fuse and tested pump again by shorting GRN-Blk to GND and not working so washer pump is probably FUBAR'd - fantastic... then realised I was driving the pump with 12V instead of pulling it down. Bellend!
- Tried the wiper functions and did not get any satisfactory results and blew a fuse for the wiper motor in the process.
So in summary I need to go back to the drawing board, give me head a shake, and try again!
