The next step along the path was to include the alarm clock functionality in addition to standard music controls making this a bedside gadget.
Making an alarm clock in python is fairly straightforward so I wanted to focus instead on the controls. The alarm goes off daily according to the time you set in the python script.
When that timestamp is hit the current song will play, the LCD will turn on displaying the current date/time, and the LED will go to full brightness.
To turn off the alarm you have two choices; snooze or off
Sticking with the idea of a 100% touch-less interface and wanting to leverage the controls that are already built in for music control I settled on the following for now:
Snooze = Waving your hand over 10cm above the device pauses the playback for 7 minutes and leaves the LCD with date/time on. The motion is similar to quickly swiping the air above the clock
Alarm Off = Bringing your hand down to 0cm on the device turns off the playback, turns off the LCD backlight and LED, and resets the alarm for the next day. The motion is similar to bringing your hand down onto the device (like hitting off button on your alarm clock)
I'm merging this capability in the existing code but I'm leaving the lightouch.py code untouched so you have the option of music player or music player+alarm clock.
import serial
import mpd
import subprocess
import alsaaudio
import os
import datetime
import time
ser = serial.Serial('/dev/ttyS0', 9600) # Change /dev/* value to match your arduino serial interface device
ser.timeout=.05 # Timeout reduces CPU usage
mixer = alsaaudio.Mixer('PCM', 0) # Which audio mixer to control
changecheck=" " # variable that 'watches' to see if the song has changed
counter=0 # variable used to delay the time to redisplay the Artist/Song after changing volume
#alarmhour=int(input("Enter Alarm Hour: "))
#alarmminute=int(input("Enter Alarm Minute: "))
alarmhour=0 # #Enter alarm hour
alarmminute=36 #Enter alarm minute
snooze=0
flag=0
masteralarmhour=alarmhour #Keep track of a universal alarm hour
masteralarmminute=alarmminute #Keep track of a universal alarm minute
client = mpd.MPDClient()
client.connect("localhost", "6600")
def translate(value, leftMin, leftMax, rightMin, rightMax): # Used to translate the value of volume to a 0-100 range for accurate display
# Figure out how 'wide' each range is
leftSpan = leftMax - leftMin
rightSpan = rightMax - rightMin
# Convert the left range into a 0-1 range (float)
valueScaled = float(value - leftMin) / float(leftSpan)
# Convert the 0-1 range into a value in the right range.
return rightMin + (valueScaled * rightSpan)
while True:
now=datetime.datetime.now() #get current time
dt = list(time.localtime()) #break down into list
hour = dt[3] #set hour
minute = dt[4] #set minute
second = dt[5] #set second
if hour == alarmhour and minute == alarmminute and second == 0 and flag==0:
client.play() #Play music
mixer.setvolume(100) #At max volume
ser.write(now.strftime("%a, %b %d %Y")) #Display date to LCD
ser.write('@') #Trigger to skip to next LCD row
ser.write(now.strftime(" %H:%M ")) #Display time to LCD
ser.write('%') #Trigger to pause ultrasonic inputs
print now.strftime("%Y-%m-%d %H:%M")
flag=1; #Alarm is playing
snooze=1; #Snooze is available
snafu=ser.readline().decode('utf-8','ignore')[:-2] #Read serial input
SongInfo=client.currentsong() #Pulls information from MPD
artist=SongInfo['artist'] #Artist info
song=SongInfo['title'] #Song info
if len(song) > 16: #Chops artist length to LCD width (16 characters)
choppedsong = song[0:15]
else:
choppedsong = song[0:(len(song))]
if len(artist) > 16: #Chops artist length to LCD width (16 characters)
choppedartist = artist[0:15]
else:
choppedartist = artist[0:(len(artist))]
if counter==20: #Amount of time to redisplay the Artist/Song after volume change
changecheck=''
counter=counter+1
if counter>=21:
counter=21
if changecheck != choppedsong: #If counter met or song changed write to LCD
ser.write(choppedsong)
ser.write('@')
ser.write(choppedartist)
ser.write('@')
print choppedsong
print choppedartist
changecheck=choppedsong
if snafu == 'Pause': #Read serial input for Pause, Next, or Volume
client.pause(1)
print(snafu)
ser.write(' Paused') #Print to LCD
ser.write('@') #'@' symbol tells the arduino to move to the next row on the LCD
counter=21;
flag=0; #Alarm already triggered
snooze=0; #Turn off snooze
alarmhour=masteralarmhour #Reset alarm hour
alarmminute=masteralarmminute #Reset alarm minute
elif snafu == 'Next':
client.next()
print(snafu)
elif snafu.isdigit() and snooze==1: #If in volume spectrum and alarm is playing
client.pause(1)
alarmminute=minute+9 #Reset alarm for 9 minutes from now
if alarmminute>=60: #Make sure it doesn't go outside of time format
alarmminute=0
alarmhour=alarmhour+1
print "Snooze"
ser.write(' Snooze ') #Write Snooze to the LCD
#ser.write('~') #Trigger code to pause all input from arduino for a short time
flag=0; #Flag alarm to go off again
#snooze=0; #Flag snooze to go off again
elif snafu.isdigit() and snooze==0: #If in volume and alarm is not playing
client.play() #Standard music controls
mixer.setvolume(int(snafu)) #Set raspi volume according to ultrasonic distance
counter=0
ser.write('Vol: ') #Print volume level to LCD
print(int(translate(int(snafu),70,100,0,100)))
ser.write(snafu)
ser.write('@')
flag=1; #Tell alarm not to go off when playing normally
<br>
