ATMEGA328P has two supply pins: VCC and AVCC. AVCC pin is supply of ADC converter and generally should be clean supply. So I think to use two 5V regulators. One for VCC and one for AVCC. But this is not enough. Measurements done by switching resistors using digital I/O pins. So actually VCC supply will be part of measurement anyway. May be it will be necessary to add buffer or mux that uses AVCC as supply to solve this problem.
Alexander Stepanov
