At wiki the formulas for motion are to find in chapter uniform acceleration is the formula that describes the distance of particle after a certain time with an initial speed and an acceleration.
with www.wolframalpha.com I solved the formula for the time.
the result is:
with this result I can calculate how much time a particle needs for a distance of e.g. 1mm with a initial speed and a acceleration from the field.
The acceleration of a electron in a electrical field is:
E is the field strength of the simulation [V/m] q is the elementary charge of a electron q=1.6021766208(98)×10−19 [A*s] and m is the mass of a electron m=9.10938356(11)×10−31 kg (link to parameter for a electron
I think that still something is wrong as actually the yellow columns above should be equal. if I calculate the distance absS with the partly movement of the particle in x and y direction it is unequal to the distance s (1mm) what was use to calculate ts.
If somebody has a idea why have this behavior let it me know. I uploaded the with the calculation to GitHub https://github.com/Chris-deerleg/FEMM-4.2
