Captains Log #1
A project log for Open Source Micro Cassette Player
It wont look like the elbow elbow cassette player (different)
ricardo-ferroRicardo Ferro • 05/09/2017 at 20:43•7 Comments
So far I was looking for a Square Card reader in my room, since they use tape heads. I found a 1st gen Square card reader and a 5th gen square card reader (which broke into tiny pieces when i tried taking it apart ). Based off Google search this 1st gen tape head reads mono audio. The next part is to design and assemble an amplifier to play audio off the cassette.
Angelo123 wrote 05/10/2017 at 18:15 • point
Cool
Morning.Star wrote 05/10/2017 at 06:00 • point
Hey Riccardo :-)
Neat idea. Speaking from experience your pre-amp will need to have an 'RIAA compensated frequency response' to play music off a cassette tape. To reduce rumble and hiss from the media the lower and higher frequencies are compressed and band-passed before recording, and then expanded by the compensator before playback. Using a flat response amp will give you a very mushy playback...
Morning.Star wrote 05/10/2017 at 09:50 • point
Yeah perfect, that should do it. Anything with a flatter response in the middle and slopes off the top and bottom edges will play it back better than a Mic pre-amp.
Thanks for the shout out.
AVR wrote 05/10/2017 at 13:25 • point
I thought that cassettes are not encoded this way, vinyl records are in order to get the audio to fit the dynamic range of the medium. Like when I say make a cassette from one of my records, I take the preamp output from the phono preamp and run it into the cassette deck and just record the decoded audio to cassette like that. Everything plays back all nice too. Just curious.
Morning.Star wrote 05/10/2017 at 22:38 • point
That Dolby double-D symbol means it was squished with their response curve, most of it was. Vinyl has a steeper cutoff to remove the rumble from that, yes, which is RIAA, I got confused with the acronyms. However the principle is the same. The response curve from the tape head is dealt with by the preamp itself, the same as in a vinyl setup. So yes, it will sound fine coming out of the preamp. The filtering and compression / decompression was meant to be transparent to the user, thats all, it's a stage lower than phono jacks.
Dont forget you cant record on vinyl so it only has a filter to remove noise, not a decoder to expand a coded signal ;-)
AVR wrote 05/11/2017 at 19:39 • point
hey thanks for explaining what you meant!! As soon as you said Dolby I was like "so that's what he meant" hahahaha
