1. Open the sleeping bag and evenly distribute the carbon rope on the inner surface, as on the photo.
2. Prepare several lengths of wire and lay them as shown in the photo and on an equivalent circuit.
3. Strip wires at the intersection points with the carbon ropes and wrap it tightly.
4. Connect female power socket plug connector.
Secure carbon ropes and wires with duct tape.
With
such a length and voltage of 12 volts, the carbon rope will only heat
up to 30-40 degrees Celsius. At this temperature the duct tape will not
melt or peel off.
I've already used this sleeping bag in several hikes and the duct tape is still securely in place. It is soft enough and does not interfere with sleeping. The volume of the collapsed sleeping bag did not change. I think this is a good solution for express DIY designs but in the next project I want to use a sleeping bag with a detachable lining to sew the carbon cord to the lining.
shenzhen
vincentmakes
Steve Hernandez
extremerockets
You can use it with any USB battery pack 5v/12v, or with USB battery pack 5v if you change carbon length to 50 cm.
