Photo 1 shows project completed
Photo 2 shows the vent fan to be removed
Photo 3 shows vent fan relocated on control board
Photo 4 shows the bed wires are nicely bundled together so you know which ones they are and the hole you will pull them through
Photo 5 shows that the heater wires need to be removed from white plug so they will be small enough to pull through all the holes also how the wire are run ultimately through the fan vent.
Photo 6 shows the last hole to pull wires through on the bed. Cut the zip tie to release, push grommet up through and slide the wires up and out. Grommet stays around the wired and is used in the fan vent to protect the wires.
Note on fan direction: sticker side indicates which way fan blows. In the picture you see sticker side up. This means it is blowing away from board. You may choose to place fan blowing down, sticker side down. This is one of those things you decide based on what camp you live in on that subject. I just slapped it on and did not think about the direction until after the fact. If I was in less rush and gave it thought I would have put it on the other way. It does not matter which way it is on however both ways work.
I left the fan in place and just ran the wires through the crack between the bottom plate and the main case.
