This series of CPU's is based on the Scott Architecture ( from the book 'But How Do It Know' by J. C. Scott ) and modified by me.
There are 4 types of CPU's I've designed so far;
Schön Core Lite which is an 8 bit computer that is quite light on resources but does not have much flexibility in instruction set but have the basics and some inter computer management
Schön Core Standard ( Also known as 'Alpha' versions ) is the standard sized 16 bit computer which has more flexibility and is able to do so much more because it is 16 bit
Schön Core Heavy Edition ( Also known as 'Delta' versions ) is the 32 bit, relatively resource heavy but is also more flexible in the instruction set and have better inter computer management, again, because it's 32 bit
Schön Duo Core ( Also known as 'Beta' versions ) which is a CPU with two control units but one special designed ALU which can be up to 1.5 times faster than a single cored CPU ( which I independently discovered, I'm only 15 and is still in elementary school so I don't have the greatest sources for relatively complex CPU architectures )
Kim Chemnitz Chemnitz
Matt Stock
James Ots
2-Zons
