Changed the scanner and ported all designs to FreeCad. The scanner can be calibrated via set screws.
The scan head passes all tests; laser can be turned on, polygon rotates and the photo diode can be read out via the circuit.
![](https://cdn.hackaday.io/images/1173881565449441684.jpg)
![](https://cdn.hackaday.io/images/2864761565449457562.jpg)
A project log for prism laser scanner
bringing additive manufacturing to the next level
