Mark, saw your email on silver-halide printing / phographic laser enlarger. This is a cool idea. At the moment, the laser module only has 4 levels of gray scale. There is a digital potentiometer but it isn't tested at 2 MHz. Thank you for pointing out that there is similar project on Hackaday (https://hackaday.io/project/10101-direct-uv-printer-for-alternative-photography). Lasers are linear within a certain domain. There is a cutoff however. The current laser has two channels and potentiometer which can be set between 0-255. The laser doesn't turn on if the potentiometer is below 70. Also the laser power varies due to the optics. A laser systems is never uniform; the power is dependent of the scan angle. You can correct for this in your slicer. Still it can result in inaccuracies. For the rest see my emails.
Hi Rik, well done on your submission. I've sent you a note to your email on the Hexastorm web site. Did you get it ? Regards, Mark
