As said in my video, there are a lot of low hanging fruits.
The following improvements are made;
- box is much smaller
- photodiode flipped to opposite side (reduced size of box)
- springs removed to adjust height photodiode and position first cylinder lens
- added slit, simply clips all beams which are not refracted by prism
I changed the laser but want to move to a different housing, which is more compact and square.
In the image you can see the new photodiode board.
Anyhow will be on holiday coming weeks, so you'll need to wait for completion :-).
