The minimum viable product is
completely made out of PCBs. To show my gratitude to the
open-source community I added the logos of
a couple projects I use to
the laser head. Source code is available here.
A project log for prism laser scanner
bringing additive manufacturing to the next level
It was very easy to add to my pcbway order. They manage to get it from shenzen to my door in a week. The box now costs 12 euro. It is very accurate, snap fit and 100 micron tolerance. You can print text on it, change color and I have a similar process at home (laser cutter). The problem with my laser cutter is that acrylic is too brittle and POM warps due to heat. A more professional plastic enclosure makes sense, later on.
Also see https://hackaday.com/2021/09/15/the-many-ways-to-solve-your-enclosure-problems/
I'm a bit baffled as to why you decided to choose to use PCBs to construct a box. It's entirely possible to get plastic enclosures custom made ( https://envplastics.com/project-applications/plastic-enclosures ) or have existing enclosures modified ( https://toolless.com/standard-plastic-enclosures/ ) for your needs.
