In the new design, I removed the mirror and track the position of the photo diode via a reflection in the prism.
This technique has a weakness.
The weakness is as follows, if the center of the rotor is not stable but moves microns during the rotation.
This will propagate to the photo-diode.
To simplify if the rotor translates in the old design nothing happens;
In the figure below the prism is moved upward by 10 mm.. Still the photodiode is hit at the same position.
The angular position is assumed to be stable due to angular momentum build up.
