The laser head, version 0.1, is compatible with a brushless motor. While the PCB motor is also supported, it won't be the default configuration. To accurately visualize the mirror motor, a more detailed render was necessary. The NBC3111 mirror motor and a cad model in freecad is depicted below. Below a head is shown which supports the prism or mirror which is spinning.
![](https://cdn.hackaday.io/images/6730221725624668434.png)
![](https://cdn.hackaday.io/images/1266641725908557055.png)
