Spinning prism with PCB motor (bugeja style)
A project log for prism laser scanner
bringing additive manufacturing to the next level
hexastormHexastorm 01/31/2022 at 13:054 Comments
made a pcb motor bugeja style,
Thanks @gravis, for the hint
it took a lot of effort but I can spin prisms with a PCB motor.
The idea is that this enables me to further reduce manufacturing costs, assembly costs
and shrinks the size of my laser head.
The coefficient of static friction is higher than kinetic friction, the prism should be able to go quite fast
Gravis wrote 01/31/2022 at 15:02 point
I'm pretty sure I just gave you the idea... unless I've been sleepmaking stuff and sending it to you. ;)
Hexastorm wrote 01/31/2022 at 16:03 point
You did...  I had seen bugeja's motor at the hackaday prize 2019, but thought it was  "too" complicated and not strong enough..
You definitely brought it back to my attention and made me question how hard it could be, now I am quite sure it is feasible..  It will still be a challenge to make it accurate (and fast)
Gravis wrote 01/31/2022 at 17:12 point
I was trying to point out the fact that "@Gravis made a pcb motor bugeja style." from your post makes it seem like I made it when that is clearly not the case.
You have made good progress because advancements are not made in leaps and bounds but millimeters at a time.
Hexastorm wrote 01/31/2022 at 18:54 point
lol @gravis, you ar right adapted the post..
