The KISS principle is notorious hard to apply. I tried a wide range of solutions to hoover the magnets over the board.
My current solution is much simpler, I use the rotor from the mirror motor as I know this works.
You can see the result below
Next step is to turn on the laser!
Hexastorm
It seems like it would be a good idea to look into reproducing the spinning part. After you've worked out the manufacturing issues then you can confidently customize it.
