I finished the PI controller. Speed seems very stable like 1998-2002 RPM when the target is 2000 RPM. Next step is to restructure the code base and add laser measurments.
A project log for prism laser scanner
bringing additive manufacturing to the next level
This indeed is very key. As said, I now count if I have seen six magnets. This was more accurate than one specific magnet. A measurement mistake results in an error of 1/6 and not a full cycle.
There are variations in strength and position. These are however very constant. I am surprised by this as well. I now solve this via an interpolation table.
Nice! I hope this level of stability is sufficient but if not, it's still a good start. Just a thought but if you are reading a hall sensor then keep track of rotation using the same magnet. Minor variations in the positioning and/or the strength of the magnets could result in varying trigger times.
