From fabbaloo, a new research paper proposes an unusual 3D printing process that uses a rod instead of a flat print plate.
It would make a lot of sense to remove the slit and the beamer. I would use a laser prism scanner instead. The laser prism scanner can do 20k rpm x 8 lines. It would never need to stop..
I will get back to this
