The extension module is mounted on top of a compute module. The female 20 pin header is not shown. Power is supplied via a USB-C connection requiring a 12V charger. An on-board converter (large black chip) reduces this to 5V for the compute board.
The board has three stepper drivers TMC2208 and three end stops. A 20-pin connector interfaces with the laser head. Another 20 pin connector is free to use. The laserhead needs to move less than a FFF printer due to the polygon, as such not a lot of current for the stepper motors is required. It is assumed this is less than 1 Amp.
Note: A USB-C connection with an FPGA for the laser head was initially considered but is currently postponed.
Hexastorm
Hey gravis, cool your still looking up this project. Currently laser head is mounted on a Cartesian frame which has 3 axes and thus stepper motors and drivers. The prism motor driver is in the laser head. You need two drivers to move in a snake line pattern.
You could have saved yourself a stepper driver if only you had gone with a Polar frame. ;)
Sorry, I missed this update! I'm a bit confused though. Why are there three stepper motor drivers? I was under the impression that only one was needed and it's for spinning the polygon. Is the idea to drive three polygons?
