This is a concept design that I drew up this morning. Because sometimes you need a firm grip on your balls. And, well... custom jaws can get you there.
I will likely make more of these up in the future with different custom jaw ideas.
The aesthetics are likely to change. But, this is meant to be our "Kickstarter Edition" of The Maker's Vise. The aluminum would be colored green through interference coloring during the anodize process.. and then, we could surface-dye additional colors using a screen-print.
