I designed a new type of SwitchMote, it's a PSU that can drive heavy AC loads of up to 30A through the 30A-250V onboard relay. It can of course be controlled wirelessly when mated with a Moteino. Here are the components required for assembly:
A project log for The Moteino Framework
Automation framework based on wireless Moteino nodes.
