The initial run seems OK, though I think the through-hole could shrink and still be compatible with many components. I'll be shifting it around for Rev B, but the initial boards work OK. The silkscreen is off on some of the boards, but most seem to be aligned and legible. I'll remove the perf holes next to the connectors to provide more soldering space for riser connectors.
Chris Hamilton
