Start talking
A project log for Stockie - item centric shopping list
What if every time you run out of a product, the smart tag on it would instantly add it to your shopping list, at the touch of a button?
electrobobelectrobob • 07/30/2014 at 21:49•0 Comments
One of the first steps of the built is to achieve communication between the stockie tags and the main node which will be the gateway to the server. The tags are based around an attiny88 microcontroller and a NRF24l01+ radio module. The gateway will use a router coupled with an XMEGA micro controller along with a NRF24L01+ high power module and external antenna (here shown with a regular one). In this combination the communication range is sufficient throughout the average house, powerful enough to pass through two floors.
