First panels are completed and can go online. Here are the first two assembled PCBs, one for development and one for actual usage in the kitchen.
As you can see, there is a lot of empty space in the box, but I will design the whole thing again for the next version, the panel should not be much thicker than a battery and PCB.
The buttons are designed to come out of the box surface just enough so that they can be pressed through the front plastic panel that comes over them.
And the first completed panel from the front which will take place in one of my cabinets in the kitchen. I have chosen the labels quite randomly, I almost never need flour, since I don’t cook.
