Controller now integrated inside feeder. Can be used/flashed over usb serial. Also contains rs485 for connecting multiple feeders into same bus(spring pins not visible). 2 motor drivers, 4 buttons and 1 rgb led on top.
Yep, i have tried to use existing, well functioning, reasonably priced parts whenever possible. That's the road i like to go.
Looks nice but it also looks like it's made from "parts I know" rather than optimizing for cost which is understandable when making a prototype. I look forward to the release of the design to see how people modify it. :)
