My friend Dylan Brophy inspired me to investigate the ability to output the cyrillic text using different output devices, supported by Terminal-BASIC.
1. Using symbols others then capital latin in identifiers not possible and unnecessary.
2. USART output.
The job is done by the terminal or (terminal emulator) as long as you use a 1-byte cyrillic encoding (CP-866, KOI8-R, KOI8-U, Windows-1251 ...);
3. Output using TVoutEx, UTFT libraries and devices such as NGT20.
The character set either raster or vector should be extended. The memory resources in this case is main restriction. I think the encodings, which were mentioned above, are not suitable for this case because they define full cyrillic letters set for only 1-2 language and doubles the letters with same look as latin ones. There was interesting encoding Код УПП (punch card device code) which was used on БЭСМ-6 mainframes, defines single latin-cyrillic charset. But it has only capital letters and was incompatible with ASCII.
So I decided to define the encoding, containing all cyrillic symbols without doubling the same-looking latin.
I gather cyrillic letters from 8 alphabets (6 modern and 2 dead). The second part of ASCII will be formed from symbols, differs from latin, with the order ascending by the "points" of this letter in the following rating. This will allow to reduce the number of supported symbols, cutting the tail of the table.
Symbol | Early Cyrillic | Modern russian | Russian before 1917 | Belorussian | Ukrainian | Serbian | Bulgarian | Macedonian | All |
1 | А | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
2 | Б | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
3 | В | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
4 | Г | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
5 | Ѓ | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | 1 |
6 | Ґ | 0 | 0 | 0 | 0 | 1 | 0 | 0 | 0 | 1 |
7 | Д | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
8 | Ђ | 0 | 0 | 0 | 0 | 0 | 1 | 0 | 0 | 1 |
9 | Е | 0 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 7 |
10 | Ё | 0 | 1 | 0 | 1 | 0 | 0 | 0 | 0 | 2 |
11 | Є | 1 | 0 | 0 | 0 | 1 | 0 | 0 | 0 | 2 |
12 | Ж | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
13 | З | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
14 | И | 1 | 1 | 1 | 0 | 1 | 1 | 1 | 1 | 7 |
15 | Ї | 1 | 0 | 0 | 0 | 1 | 0 | 0 | 0 | 2 |
16 | Й | 0 | 1 | 1 | 1 | 1 | 0 | 1 | 0 | 5 |
17 | К | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
18 | Ќ | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | 1 |
19 | Л | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
20 | Љ | 0 | 0 | 0 | 0 | 0 | 1 | 0 | 1 | 2 |
21 | М | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
22 | Н | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
23 | Њ | 0 | 0 | 0 | 0 | 0 | 1 | 0 | 1 | 2 |
24 | О | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
25 | П | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
26 | Р | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
27 | С | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
28 | Т | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
29 | Ћ | 0 | 0 | 0 | 0 | 0 | 1 | 0 | 0 | 1 |
30 | У | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
31 | Ў | 0 | 0 | 0 | 1 | 0 | 0 | 0 | 0 | 1 |
32 | Ф | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
33 | Х | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
34 | Ц | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
35 | Ч | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
36 | Џ | 0 | 0 | 0 | 0 | 0 | 1 | 0 | 1 | 2 |
37 | Ш | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 8 |
38 | Щ | 1 | 1 | 1 | 0 | 1 | 0 | 1 | 0 | 5 |
39 | Ъ | 1 | 1 | 1 | 0 | 0 | 0 | 1 | 0 | 4 |
40 | Ы | 1 | 1 | 1 | 1 | 0 | 0 | 0 | 0 | 4 |
41 | Ь | 1 | 1 | 1 | 1 | 1 | 0 | 1 | 0 | 6 |
42 | Ѣ | 1 | 0 | 1 | 0 | 0 | 0 | 0 | 0 | 2 |
43 | Э | 0 | 1 | 1 | 1 | 0 | 0 | 1 | 0 | 4 |
44 | Ю | 1 | 1 | 1 | 1 | 1 | 0 | 0 | 0 | 5 |
45 | Я | 0 | 1 | 1 | 1 | 1 | 0 | 1 | 0 | 5 |
46 | I | 1 | 0 | 1 | 1 | 1 | 0 | 0 | 0 | 4 |
47 | J | 0 | 0 | 0 | 0 | 0 | 1 | 0 | 1 | 2 |
48 | S | 1 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | 2 |
After addition of the Macedonian alphabet encoding variant looks like this:
dec | hex | ASCII | КОЭ-13 (CUE-13 Cyrillic United Economical) |
0 | 0 | NUL |
1 | 1 | SOH |
2 | 2 | STX |
3 | 3 | ETX |
4 | 4 | EOT |
5 | 5 | ENQ |
6 | 6 | ACK |
7 | 7 | BEL |
8 | 8 | BS |
9 | 9 | TAB |
10 | A | LF |
11 | B | VT |
12 | C | FF |
13 | D | CR |
14 | E | SO |
15 | F | SI |
16 | 10 | DLE |
17 | 11 | DC1 |
18 | 12 | DC2 |
19 | 13 | DC3 |
20 | 14 | DC4 |
21 | 15 | NAK |
22 | 16 | SYN |
23 | 17 | ETB |
24 | 18 | CAN |
25 | 19 | EN |
26 | 1A | SUB |
27 | 1B | ESC |
28 | 1C | FS |
29 | 1D | GS |
30 | 1E | RS |
31 | 1F | US |
32 | 20 | SPACE |
33 | 21 | ! |
34 | 22 | " |
35 | 23 | # |
36 | 24 | $ |
37 | 25 |
38 | 26 | & |
39 | 27 | ' |
40 | 28 | ( |
41 | 29 | ) |
42 | 2A | * |
43 | 2B | + |
44 | 2C | , |
45 | 2D | - |
46 | 2E | . |
47 | 2F | / |
48 | 30 | 0 |
49 | 31 | 1 |
50 | 32 | 2 |
51 | 33 | 3 |
52 | 34 | 4 |
53 | 35 | 5 |
54 | 36 | 6 |
55 | 37 | 7 |
56 | 38 | 8 |
57 | 39 | 9 |
58 | 3A | : |
59 | 3B | ; |
60 | 3C | < |
61 | 3D | = |
62 | 3E | > |
63 | 3F | ? |
64 | 40 | @ |
65 | 41 | A |
66 | 42 | B |
67 | 43 | C |
68 | 44 | D |
69 | 45 | E |
70 | 46 | F |
71 | 47 | G |
72 | 48 | H |
73 | 49 | I |
74 | 4A | J |
75 | 4B | K |
76 | 4C | L |
77 | 4D | M |
78 | 4E | N |
79 | 4F | O |
80 | 50 | P |
81 | 51 | Q |
82 | 52 | R |
83 | 53 | S |
84 | 54 | T |
85 | 55 | U |
86 | 56 | V |
87 | 57 | W |
88 | 58 | X |
89 | 59 | Y |
90 | 5A | Z |
91 | 5B | [ |
92 | 5C | \ |
93 | 5D | ] |
94 | 5E | ^ |
95 | 5F | _ |
96 | 60 | ` |
97 | 61 | a |
98 | 62 | b |
99 | 63 | c |
100 | 64 | d |
101 | 65 | e |
102 | 66 | f |
103 | 67 | g |
104 | 68 | h |
105 | 69 | i |
106 | 6A | j |
107 | 6B | k |
108 | 6C | l |
109 | 6D | m |
110 | 6E | n |
111 | 6F | o |
112 | 70 | p |
113 | 71 | q |
114 | 72 | r |
115 | 73 | s |
116 | 74 | t |
117 | 75 | u |
118 | 76 | v |
119 | 77 | w |
120 | 78 | x |
121 | 79 | y |
122 | 7A | z |
123 | 7B | { |
124 | 7C | | |
125 | 7D | } |
126 | 7E | ~ |
127 | 7F | DEL |
128 | 80 | Ç | Б |
129 | 81 | ű | Г |
130 | 82 | é | Д |
131 | 83 | â | Ж |
132 | 84 | ä | З |
133 | 85 | à | Л |
134 | 86 | å | П |
135 | 87 |
У |
136 | 88 |
Ф |
137 | 89 |
Ц |
138 | 8A | è | Ч |
139 | 8B | ї | Ш |
140 | 8C | î | И |
141 | 8D | ì | Ь |
142 | 8E |
Й |
143 | 8F |
Щ |
144 | 90 |
Ю |
145 | 91 |
Я |
146 | 92 |
Ъ |
147 | 93 |
Ы |
148 | 94 |
Э |
149 | 95 |
Є |
150 | 96 |
Ё |
151 | 97 |
Ї |
152 | 98 |
Љ |
153 | 99 |
Њ |
154 | 9A |
Џ |
155 | 9B |
Ѣ |
156 | 9C |
Ґ |
157 | 9D |
Ѓ |
158 | 9E |
Ђ |
159 | 9F |
Ќ |
160 | A0 |
Ћ |
161 | A1 |
Ў |
162 | A2 |
б |
163 | A3 |
в |
164 | A4 |
г |
165 | A5 |
д |
166 | A6 |
ж |
167 | A7 |
з |
168 | A8 |
л |
169 | A9 |
п |
170 | AA |
т |
171 | AB |
ф |
172 | AC |
ц |
173 | AD |
ч |
174 | AE |
ш |
175 | AF |
и |
176 | B0 |
ь |
177 | B1 |
й |
178 | B2 |
щ |
179 | B3 |
ю |
180 | B4 |
я |
181 | B5 |
ъ |
182 | B6 |
ы |
183 | B7 |
э |
184 | B8 |
є |
185 | B9 |
ё |
186 | BA |
ї |
187 | BB |
љ |
188 | BC |
њ |
189 | BD |
џ |
190 | BE |
ѣ |
191 | BF |
ґ |
192 | C0 |
ѓ |
193 | C1 |
ђ |
194 | C2 |
ќ |
195 | C3 |
ћ |
196 | C4 |
ў |
