We received some questions regarding the WLAN signals coupling to the RF
output. Some people were concerned that phase noise would increase with
WLAN module (ESP8266) active. Our tests show that there is no need to
worry about WLAN. First of all, whether you use the on-board WLAN or
not, WLAN signals are all around us. Secondly, we have taken very
serious measures to cope with all kinds of couplings and leakages on the
board. As you can see in the detailed PCB picture
on the campaign page, ERASynth PCB is partitioned to protect sensitive
areas from the outside world and from the other noisy areas on the board
itself (such as switch-mode regulators, MCU etc…). There is a
tremendous amount of filtering on every supply and control line. The
picture below shows ERASynth’s RF output connected to a spectrum
analyzer while the WLAN module is activated.
edensrock
