4 voice (Bass drum, snare drum, open hat, closed hat) analog drum machine originally controlled from an Android device via IOIO (microcontroller) thanks to MackeMints (http://projects.hackaday.com/hacker/812) pro programming skillz.
Version 2 is under development, this time using an Arduino Uno as sequencer plus the addition of a compressor with "aux-mixer" for parallell compression capabillity.
Drum pads for live-playing and sequence recording is to be added in version 2 aswell.
Analog oscillators kan be found here:
http://ericarcher.net/devices/tr808-clone/
