Today I added the spacer between electrodes and oh what fun that is. I was originally going to use the yellow plastic that came with original swatter but I was lazy and figured weed-eater string or 3d printer PLA would work. Well I don't own a weed-eater so PLA it was. I originally made a suture line from tiny wire, tape and thread to ties down the PLA to the base electrode. That was a slow method and would work but I wanted instant gratification so I broke out the hot glue gun and went to work. Took about 15minutes, 2 burned fingers (D batteries make great backing for hot glue), and 6 feet of PLA to get it close enough to done. I found that I could loop the spacer and glue more precisely than attempting to cut individual lines. If I finish this prototype maybe I'll go back and 3d print a fitting version so I will not have to mess with hot glue and make it look more "finished".
