I pulled the code from a project by Bajdi as it was the closest to what I thought was workable with my setup.
Still some wheel problems. It might be as simple as not hooking the motorshield upp correctly (doubtful as Seeed's demo works) or adapting this from a bare chip has screwed up some timings. All I know is, the sensor sweeps and reports and the drive variables and commands show up in the serial monitor debugger.
http://www.bajdi.com (your number one source for buggy Arduino sketches)
Simple obstacle avoiding robot made from parts mostly sourced from Ebay
Micro controller = ATmega328P-PU with Arduino bootloader (3.5$ @ Eb.. noooo Tayda Electronics)
Using a L293D (bought from my favourite Ebay seller Polida) to drive 2 yellow "Ebay motors with yellow wheels"
Detecting obstacles with an SR04 ultrasonic sensor (uber cheap on Ebay)
SR04 sensor mounted on SG90 servo (you can get these servo very cheap on ... oh yes you guessed it: EBay)
Adapted by Ross Potts 7-29-2014 for Seeed Motor Shield V2 BUT I'M STILL HAVING WHEEL ISSUES
#include "NewPing.h" //library for the SR04 ultrasonic sensor
#include "Servo.h" //servo library, SR04 is mounted on this servo
#include "MotorDriver.h"
Servo HeadServo;
//Servo LarmServo;
//Servo RarmServo;
#define TRIGGER_PIN 2 //using analog pins as digital for SR04 sensor
#define ECHO_PIN 3 //because I just happened to plug them in here
#define MAX_DISTANCE 200 //the sensor can't measure much further then this distance
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
#define runEvery(t) for (static typeof(t) _lasttime;(typeof(t))((typeof(t))millis() - _lasttime) > (t);_lasttime += (t))
//const int EN1 = 8; //enable motor 1 = pin 1 of L293D
//const int direction1 = 11; //direcion motor 1 = pin 2 of L293D
//const int EN2 = 12; //enable motor 2 = pin 9 of L293D
//const int direction2 = 13; //direction motor 2 = pin 15 of L293D
// leds are very handy for testing
//const int redLed = 10; // this led will lit up when the robot drives forward
//const int greenLed = 11; // this led will lit up when the robot drives backward
//const int yellowLed = 12; // this led will lit up when the robot turns left
//const int whiteLed = 13; // this led will lit up when the robot turns right
int uS; //value of SR04 ultrasonic sensor
int distance; //distance in cm of ultrasonic sensor
int pos = 90; //start position of servo = 90
int servoDirection = 0; // sweeping left or right
int robotDirection = 0; //0 = forward, 1 = backward, 2 = left, 3 = right
int lastRobotDirection; //last direction of the robot
int distanceCenter;
int distanceLeft;
int distanceRight;
int servoDelay = 20; //with this parameter you can change the sweep speed of the servo
long previousMillis = 0;
const int interval = 650; //interval to switch between the robotDirection, this value will determine
//how long the robot will turn left/right when it detects an obstacle
void setup() {
motordriver.init();
motordriver.setSpeed(200,MOTORB);
motordriver.setSpeed(200,MOTORA);
Serial.begin(9600); //to use the serial monitor
HeadServo.attach(4); //Head servo on pin 8
HeadServo.write(pos); //center Head servo
// LarmServo.attach(5); //Left Arm servo on pin 5
// LarmServo.write(pos); //center Left Arm servo
// RarmServo.attach(6); //Right Arm servo on pin 6
// RarmServo.write(pos); //center Right Arm servo
delay(1500); // delay so we have some time to put the robot on the floor
void loop()
sweepServo(); //function to sweep the servo
getDistance(); //function to get the distance from the ultrasonic sensor
if (pos >= 15 && pos <= 45)
distanceRight = distance; //servo is to the right so measured distance = distanceRight
if (pos >= 135 && pos <= 165)
distanceLeft = distance; //servo is to the left so measured distance = distanceLeft
if (pos > 70 && pos < 110)
distanceCenter = distance; //servo is centred so measured distance = distanceCenter
if (distanceCenter >= 25) // coast is clear, full power forward
robotDirection = 0; //move forward
else //obstacle detected, turn left or right?
if (distanceLeft > distanceRight)
robotDirection = 2; //turn left
if (distanceLeft < distanceRight)
robotDirection = 3; //turn right
if (distanceLeft <= 5 && distanceCenter <= 5 || distanceRight <= 5 && distanceCenter <= 5)
robotDirection = 1; // we are stuck <img src="http://www.bajdi.com/wp-includes/images/smilies/icon_sad.gif" alt=":("> lets try and backup
unsigned long currentMillis = millis(); //set a timer
if(robotDirection == 0 && robotDirection == lastRobotDirection)
forward();
lastRobotDirection = robotDirection;
debugMotor();
if(robotDirection == 0 && robotDirection != lastRobotDirection && currentMillis - previousMillis > interval )
forward();
previousMillis = currentMillis;
debugMotor();
if(robotDirection == 1 && robotDirection == lastRobotDirection)
backward();
debugMotor();
if(robotDirection == 1 && robotDirection != lastRobotDirection && currentMillis - previousMillis > interval )
backward();
debugMotor();
if(robotDirection == 2 && robotDirection == lastRobotDirection)
left();
debugMotor();
if(robotDirection == 2 && robotDirection != lastRobotDirection && currentMillis - previousMillis > interval )
left();
debugMotor();
if(robotDirection == 3 && robotDirection == lastRobotDirection)
right();
debugMotor();
if(robotDirection == 3 && robotDirection != lastRobotDirection && currentMillis - previousMillis > interval )
right();
debugMotor();
void forward()
motordriver.goForward();
Serial.println("Going Forward");
delay(2000);
void stop()
motordriver.stop();
Serial.println("Going Nowhere fast");
delay(1000);
void backward()
motordriver.goBackward();
Serial.println("Going Backward");
delay(2000);
void left()
motordriver.goLeft();
Serial.println("Going Left");
delay(2000);
void right()
motordriver.goRight();
Serial.println("Going Right");
delay(2000);
/* SERVO AND SENSOR COMMANDS - BEGIN */
void getDistance()
runEvery(40) //loop for ultrasonic measurement
uS = sonar.ping();
distance = uS / US_ROUNDTRIP_CM;
if (uS == NO_ECHO) // if the sensor did not get a ping
distance = MAX_DISTANCE; //so the distance must be bigger then the max vaulue of the sensor
Serial.print("Ping: "); //to check distance on the serial monitor
Serial.print(distance);
Serial.println("cm");
void debugMotor()
Serial.print("RobotDirection: "); //to check current direction variable on the serial monitor
Serial.println(robotDirection);
void sweepServo()
runEvery(servoDelay) //this loop determines the servo position
if(pos < 165 && servoDirection == 0) // 165 = servo to the left
pos = pos + 5; // +1 was to slow
if(pos > 15 && servoDirection == 1) // 15 = servo to the right
pos = pos - 5;
if (pos == 165 )
servoDirection = 1; //changes the direction
if (pos == 15 )
servoDirection = 0; //changes the direction
HeadServo.write(pos); //move that servo!
/* SERVO AND SENSOR COMMANDS - END */
void WalkArms ()
void ScaredArms ()
txdo.msk
