Here is a SS of the hex --> voltage chart. Simple pattern after the first .07. It is (5) .08 tehn a .07, all the way to the end.
I am in the processing of putting togethor a simple VB.NET with zedgraph component
to read the output from PORTMON and plot it on a graph and if time
permits ultimatly automaticall decipher the I2C messages.
App
will be able to read the PORTMON data log file, look for the pattern of
55, data1, data2, AA and if all is valid (not more than 2 data sequences
between the 55 and AA) output the data to a graph. The output captured
from the scope is 50uS at 5V for both channels. Will also prob add in a
logic mode that will use a couple of params at first to determine what
is considered "HI" and "LOW" so it's not a voltage reference chart.
