There are a few test boards I made without buttons but I did have one before the current with the Pro Mini on top of the board before I designed it upside-down, underneath the board and removed the large screen SD card socket for the current version. The ST7735, ILI9341 and (monochrome) Nokia 3310/5110 have the same pinouts and can be used. I now need to get a Teensy.
