We have shrunk the module by going 4 layer. You can find the new smaller version available in the 'small' directory on github. The large version hasn't changed much, though we did redo it's layout in an attempt to see if we could add more components on the same board size. To shrink any further, we will need to switch to the much smaller WLCSP 3x3mm version.
Chris Hamilton
At 2mm x 1.6mm, they are not much bigger than a cap. I used 3 of those packages here: https://hackaday.io/project/1347-fpga-computereval-board
Very nice M4 chip! I would use that instead of the Freescale K22 if it was available sooner.
