We already have a linux and mysql installed on the Odroid. We need two more pieces to make the LAMP Server complete. The A and the P stand for Apache and Perl, PHP, Python.
We have made a few changes so we want to run the command:
sudo apt-get update
sudo apt-get upgrade
answer y when prompted.
Install Apache and PHP:
sudo apt-get install apache2 php5 libapache2-mod-php5
we need to enable the htaccess type:
sudo nano /etc/apache2/apache2.conf
under htaccess change Require all denied to Require all granted
restart apache with the command:
sudo service apache2 restart
we need to change one more file:
sudo nano /var/www/html/info.php
then type this in the file:
<?php
phpinfo();
Now we are able to check both the apache and php servers. In your browser type the following URL's
http://your ip
you should see the apache start page or a page that says it works but there is not content next you can type: http://yourip/info.php
you should be able to see the php information page
