Step 9: CONGRATULATIONS!!! You are the proud owner of a server
A project log for Linux Tutorial: Odroid U3 Server w/ Seafile Cloud
I posting this to give a feel for the Odroid U3. There is a forum but not a lot of documentation out there.
tlankford01tlankford01 • 08/06/2014 at 02:25•0 Comments
This took a short while but you have a the makings of a great server. This is setup to work within your LAN while you learn how to use the server and implement security measures that you will want in place before you go live with a blog or personal webpage. I will be installing Roundcube mail service, phpMyAdmin, and No-IP as my DDNS. There are lots of ways to go about this. I want to publish this so I will be updating with screenshots and other things soon. I hope this helps. You can follow almost all the same instructions for installing on a Raspberry Pi as well. Thank you for checking out my project and I hope that it helps.
