I was concerned about securing my projects to my clients, having to burn some fuses in the chip is not enough, so i decided to add a small chip that acts as a key. the key has two modes , encode and decode configurable from a jumper switch.
The chip communicates through a serial port and uses aes or hash/sha1 encryption.
it can be used to validate a key before loading the main program or used to validate a section of the code.
I am still working on my prototype but will publish more details as i progress along.
*UPDATE 24/5/2017
I added TWI communication, it can now be wired in circuit and user can use the function to access the chip engine.
Details
I added a 256kb rom keybase and alogarithm to extract a 10 bit key and calculate a checksum .
Writing arduino library to talk to chip with simple functions.
You can , future projects will use stm32f103..
but i have a bunch of arduino mega 2560 projects .. this way i can secure it
