Power is an issue that still needs further thought. Ideally I want the sat.Send to be portable so it could be used in remote or emergency situations so this would require some kind of battery. Possible to use solar to recharge? I need to finalise the system power requirements and then I will finalise the power supply. In the meantime during prototyping power will be supplied via a desktop supply.
John Grant
