Social Fail.
Well, that survey produced an underwhelming 3 responses. To those who did respond- thank you! Your results were included in the new method below. The following pedals were listed from those 3 responses:
- Ibanez Tube Screamer
- Big Muff
- MXR Blue Box
- Danelectro Tuna Melt Tremolo
- EHX Double Muff
- Boss DD-3
New Method
This is not even close to enough data to begin feature categorization, so I am going to implement a secondary approach. The internet is full of articles on "The Top X Guitar Effects Pedals" or similar articles. I did a few searches for top 10 lists, best pedals, and different combinations in order to find as many articles as possible. For each article, I pulled out the named pedals and added them to a list. Each time a pedal appeared in an article, I increased it's occurrence tally on the list. The list soon grew to over 50, and since I am interested in gathering the popular features, I set a threshold for the occurrence tally at 3. This means that I am only considering the features for pedals that were mentioned more than 3 times in the dozen or so articles that I read. Final list after the break.
Another "problem" is that several pedals are actually expression pedals - they have a giant treadle pedal that is used to adjust a single parameter. When looking at these for features, they are outliers in form, so I am removing them from the list as well. They will not be forgotten, as they have brought an important requirement to the list - ability to remotely adjust parameters.
List of popular pedals
The following is the final list, along with the number of occurrences in the research:
| Manufacturer | Model | Occurance | Primary Effect |
| Ibanez | TS-9 | 10 | Overdrive |
| Digitech | WH-1 Whammy | 8 | Pitch Shift |
| Dallas Arbiter | Fuzz Face | 7 | Fuzz |
| Electro-Harmonix | Big Muff Pi | 6 | Distortion |
| MXR | Phase 90 | 6 | Phase shift |
| Boss | DS-1 | 5 | Distortion |
| Boss | DD-3/7 | 5 | Digital Delay |
| Electro-Harmonix | Delux Memory Man | 5 | Analog Delay |
| MXR | Carbon Copy | 4 | Analog Delay |
| MXR | Dyna Comp | 4 | Compressor |
| Pro Co | The Rat | 4 | Distortion |
| Boss | DM-2 | 3 | Analog Delay |
| Boss | CE-1 | 3 | Chorus |
| Dallas Arbiter | Rangemaster | 3 | Treble boost |
| Klon | Centaur | 3 | Clean Boost |
| Mu-Tron | III | 3 | Envelope |
| Roger Mayer | Octavia | 3 | Octave-up |
| Univox | Uni-vibe | 3 | Chorus |
| D*A*M | Professional MKII Tone Bender | 3 | Distortion |
Feature Categories
The next step is to define common features of these pedals. The pared down list will be analyzed in detail, including any available specification. The following is a list of features to catalog:
- Size (Length * Width * Height)
- Number of Audio Inputs
- Relative location of audio inputs
- Number of Audio Outputs
- Relative location of audio outputs
- Number of user inputs (knobs)
- Number of user inputs (switches)
- Number of user auxiliary inputs (remote pedals)
- Number of user outputs (lights)
- Voltage input
- Battery size
- Bypass type
- Tone control type
- Input buffer type
- Output amplifier topology
- Power supply topology
- Number of composite effects (more than one in a pedal?)
Josh
