Nearly fnished soldering the circuit on perfboard. Resistors are hooked up to the arduino and then a ribbon cable. A Johnson counter and a Darlington transistor array are also attached together and then to the duino and ribbon cable. The cable then goes to the cube and is connected via female headers. Just a little more to do before I can test.
