The main processing "engine" is now running in its own thread. Slow cameras are no longer slowing down the user interface. The framerate of the frame grabbing / processing can now be set with the command line option --frames_second
A project log for PyFSPro - Python Frame Sequence Processor
Multi purpose realtime frame sequence and video processor for a wide range of applications (schlieren videography, astroimaging and more)
