Main processing engine on separate thread
A project log for PyFSPro - Python Frame Sequence Processor
Multi purpose realtime frame sequence and video processor for a wide range of applications (schlieren videography, astroimaging and more)
mark-dammer-mm0dqmMark Dammer MM0DQM • 07/24/2017 at 07:13•0 Comments
The main processing "engine" is now running in its own thread. Slow cameras are no longer slowing down the user interface. The framerate of the frame grabbing / processing can now be set with the command line option --frames_second
