Building a box to house your crazy bundle of wires and arduino and the other stuff is kind of annoying. I know this because I did it. It was as heavy as a brick and made entirely by hand (hacksaw, drill, and files). It was made of aluminum and black acrylic and it was stupidly heavy. It weighed more than my camera before I put all the batteries in. Also, it used AA batteries. Next time it is going into a tupperware dish. Seriously.
The move from the breadboard to the case killed my project dead. I have a terrible hobbyist soldering iron and the skills to match. I think I got that LCD too hot when I resoldered it with longer leads. Dead. Since then replaced with a better one. Not so dark. Its all contrasty.
My Arduino cost around twenty bucks. The chip and crystal cost around three bucks. So I decided to ditch the Arduino (i.e. free-up) and write the chip using my Arduino as an ISP. Then I decided that I wanted to avoid removing the atmega every time I needed to upload the code. I then wired it for the Adafruit ftdi cable. Which only worked once. After grinding my head on the floor I learned that you need to have it use the reset pin on the atmega before it will upload. That cable does not have that pin and I couldn't find any instructions on how to interface with the pin it does have, which is probably the same function. It wasn't shown in the datasheet. Growl. I want that magic smoke to stay in there. I'm too new to try things.
I now faced a dilemma in how to upload my sketches? And now we are up to the present. I now have borrowed a AVR Dragon and am using Atmel Studios instead of the Arduino program. I need to research if I can use the MOSI and MISO pins for multiple purposes. Right now they are interfacing with buttons. I have an idea on how to consolidate those to fewer pins as well. My thinking goes, if I read the pin using analogRead instead of digitalRead I should be able to differentiate between them if I use differently valued resistors as pull ups. They would give different values which would be super easy to code for. Any problems I'm not seeing? I'd appreciate any comments.
The Feature Creep
