I've just created a new branch to add a PIR sensor to the clock. it's used to light-up the clock for some amount of time (currently 1 hour) when it detects movement, otherwise turn all LEDs and LCD screen off. Next is a button to override or lock the on/off state.
The PIR sensor and button will probably replace screws as "eyes" of the clock, when I redesign the enclosure.
