Socket showed up, looks awesome. Long pins on the bottom, I could probably get away with a spring hook connection to the required pins, but I think it should be simple enough to modify one of the many qfn breakout board designs to accept a socket instead of a chip directly, and then I can stick it in a breadboard. Open socket pics below:
From Above:
The Bottom:
The pics make it look big.
zacnotes
