Hey everyone, it's been quite a while since the last update! Development was intermittent over much of the past 9 months, but all those steps have added up to a new milestone revision, which has finally pulled all the parts together.
Pictures coming soon, but here are the major changes:
- Added H-bridge drive scheme for the motor, allowing more precise control over haptic patterns (active braking, for example)
- Integrated LiPo charging to the board, then took it off temporarily as I work out the more critical hardware
- Significant improvements to EMC and general grounding/signal integrity, thanks to greater accumulated knowledge. Not entirely necessary, but good to have!
- Added a micro-USB port for serial debug and charging (actually, the UART lines run directly on the TX/RX lines of the USB; they lead to a downstream FTDI board. Basically, I just like the micro-USB connector interface).
- Shrinks all around. Total dimensions are significantly reduced, making it cheaper to manufacture and hopefully easier to integrate, eventually.
- Full code cleanup, hopefully more readable than before. This isn't on Github yet, my sources are all kind of scattered and I need to redo my whole VCS setup. Everything, from HW to SW, will be up soon.
And onto the major, short term to-do list:
- Still gotta get that accelerometer online and verified. I've played with the MPU-6050 before, and have the basic code + some preliminary functions ready to go in the source, but haven't deployed yet since every board has a little defect that prevents use of the accel. I just lost another board to an unrelated power issue, so the new fixed boards should come in sometime this week, at which point we'll re-examine the IMU state of affairs. Certainly, it is the most complicated SW block in the project yet.
- Rebuild the full MVP and re-test usability characteristics, from user experience to battery life.
- Consider rolling my own ultrasonic sensor to enable a better form factor.
- And finally, start considering "wearable" integration more seriously. We have at least progressed to a less obstructive wristband, but actual ship-ready products can't have PCBs or components exposed, so I need to look into an enclosure or some other creative deployment scheme. Still a ways off though.
I'll also fix the lack of pictures soon. This is just, as the title states, a check in to confirm that Pathfinder is moving forward, but we're slowing down a bit as we move out of the barebones prototype phase. Additionally, I'll have much more time over these next few summer months, so progress is coming soon!
Neil
